Activity Forums Adobe After Effects AE7 to CS3 causing discrepancies with render quality settings
  • AE7 to CS3 causing discrepancies with render quality settings
    Posted by Jamie Bradshaw on October 10, 2007 at 2:35 pm
    Hi all.
    Apologies if this has been discussed before, I did look but couldn’t it.
    Anyway, I’ve encountered a problem regarding the render quality settings and a discrepancy between AE7 and CS3.
    Basically I created a project in AE7. In this project I needed to scale a Solid Layer’s width and height to exact pixels, so I used a simple expression that looked at two Slider effects (for width and height in pixels) and scaled accordingly. I made sure the Solid Layer’s Render Quality was set to Low, so it would be pixel accurate and without blurred edges.
    However, when this project is opened in CS3, the scaling is now a few pixels out. It appears that it is doing a different calculation from AE7.
    Any ideas?
    Jamie
    Jamie Bradshaw replied 18 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
