Activity Forums Adobe After Effects AE7 Titler question
  • AE7 Titler question
    Posted by Ara Hollisian on August 13, 2007 at 4:20 pm
    When I type a title with first letter upper case and the rest are lower case, the correct response is on the layer name but the actual title in the comp window shows all upper case. What am I doing wrong? Thanks in advance.
    Steve Roberts replied 19 years, 1 month ago 3 Members · 4 Replies
  • Goodtimej
    August 13, 2007 at 4:36 pm
    Your font is probably an all uppercase font. No lowercase for you!
  • Steve Roberts
    August 13, 2007 at 6:10 pm
    Do you have the little TT button selected on the type/character palette?
  • Ara Hollisian
    August 13, 2007 at 11:17 pm
    Steve,
    I went through all the tabs including the one you speak of. The one you speak of makes the letter upper case but smaller in size. I went through the help files but I could not find any resolution. Am I missing the obvious? I have several hun dred fonts on my hard drive and am confident that at least one of them uses lower case. Thanks in advance.
    Ara
  • Steve Roberts
    August 14, 2007 at 1:38 pm
    Not the “bigT+littleT” button, but the one with equal sized T’s. It’s the third button at the bottom of the Character palette.
