Activity › Forums › Adobe After Effects › AE7–Timewarp–is this filter REALLY quirky, or am I overlooking something…?
  • AE7–Timewarp–is this filter REALLY quirky, or am I overlooking something…?
    Posted by Koolanim8r on February 1, 2006 at 8:59 pm
    I LOVE the look of slow motion video out of timewarp, but am running into an issue…
    Say I’ve got a 5 second clip, and I want to create a slow-mo effect (say at 50% of original speed) starting 3 seconds in, and ending at 4 seconds. Logic would make me expect that I could just divide the clip at 3:00 and again at 4:00, apply timewarp at 50% to the divided clip, and hit “render”. However, it appears not to be that easy after all. It seems that the filter dialates time for the whole clip, meaning that if I set the in-point at 3 seconds and applied a 50% speed timewarp, the in-point is no longer correct. Also, I can only render up to the original duration of the clip, which means (in my example here) that anything past 2.5 seconds in the original clip can not be rendered.
    I’ve come up with a rather convoluted workflow to overcome this problem–extend the timeline considerably, enable time-remapping on the clip, extend the out-point of the time-remapped clip some distance out, apply the timewarp filter, then scroll through the resulting clip to find the ‘new’ in and out points. This delivers the desired effect, but will be painfully slow if I have to do it on MANY clips (and I’m in the midst of a project requiring MANY clips to be treated!!) Also it’s pretty painful to make the ‘jump’ from normal to slow-mo in the same clip this way…
    Am I overlooking something, or does somebody have a better work-around??
    –kp
    Kyle Palmer
    Anim8 Studios
    Golden, CO
    Steve Kilisky replied 20 years, 7 months ago 4 Members · 3 Replies
  • Mike Clasby
    February 1, 2006 at 9:18 pm
    In the time Warp Pluging, set a keyframe – !00% at 3 min, and another 100% at 4 min, then a 50% keyframe at 3 1/2 min. Interpret the footage – loop = 2(or more), and extend the clip. Not cutting required.
  • Andrew Kramer
    February 1, 2006 at 10:07 pm
    Try also to precompose the portion you want to slow down.
  • Steve Kilisky
    February 4, 2006 at 9:14 am
    Something that may not be obvious (it wasn’t to me at least) is that the Timewarp effect works differently than turning on PixelMotion in the Timeline.
    When using Pixelmotion in the timeline, the user does not have to think about the frame rate of the source footage you are retiming. In the timeline the Pixelmotion algorithm automatically knows to treat a 29.97 deinterlaced clip as an effective frame rate of 59.94.
    Timewarp uses the Comp frame rate and assumes this is the same frame rate as the footage that is being retimed which is not the case when you deinterlace. I hope I am explaining this clearly (technical writing is not my forte). So what this means is that if you are retiming 29.97 deinterlaced footage, in order to achieve the best results, you should put this footage in a 59.94 comp and then either set the output frame rate in the RQ to 29.97 or drop the retimed comp into a 29.97 comp.
    Hope that helps and doesn’t confuse more.
