Activity Forums Adobe After Effects AE7 OsX problems
  • AE7 OsX problems
    Posted by Sami Kaartinen on June 14, 2006 at 4:57 pm
    I have a major problems with getting AE7 to work in OSX. I have installed it to G5 dual 2ghz OSX 10.3.x, Powerbook 1.33ghz OSX 10.4.6, Powerbook 1.5ghz 10.3.x, Macbook Pro 2.13ghz 10.4.6 and Quad G5 10.4.6.
    The Quad is only computer where it works. In all other computers the installer gives this error: “An error occured during the installation process: 351”. In installs normally after that error, but when trying to start the program it loads couple of seconds and then crashes without error.
    we have gone trough most of the tips here: https://www.adobe.com/support/techdocs/332472.html
    but with no luck.
    Any advice welcomed.
    Thanx.
    Sami Kaartinen replied 20 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Simon Carlson-thies
    June 14, 2006 at 5:39 pm
    First off standardize the system that will make your life easier…
    next the mac book won’t run AE7 very well since Adobe has not released intel versions of their software yet…
    as to the other problems make sure that you repair disc permissions before you install.. if you have previous versions of the software get rid of them…
    try that and see what happens..
    Simon Carlson-Thies
  • Sami Kaartinen
    June 14, 2006 at 6:28 pm
    What do you mean with “standardize the system”?
    If you mean different osx versions, that is becouse AE 6.5 in 10.4.x dont support keykommands in Finnish keyboard. In our new computers there is only 10.4.x so that is one of the reasons to move to AE7.
    I’m well aware that AE is not released as universal binary and it will run under Rosetta, but it will still run better than in 1.33ghz Powerbook. At least photoshop does.
    Repairing keycommands is tested as is trying to install and run in safe-mode.
    June 14, 2006 at 7:12 pm
    Thats what I mean move all the computers to 10.4.6 and then run AE7…. get rid of AE6.5…
    And how well things run under rosetta is a matter of how complex your projects are, so whether the macbook will do better all depends on the complexity of your projects… not on the Ghz rating…
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Sami Kaartinen
    June 14, 2006 at 7:39 pm
    Getting rid of 6.5 is not a good idea since 7 is not working and we need to get the jobs done 😉 I mean that 7 is not working even if the 6.5 is never installed in the machine. With Macbook pro i can allways install 7 to a winxp, but still need to get it workin on the other G5 and powerbooks.
  • Filip Vandueren
    June 15, 2006 at 12:12 am
    did you try the adobe tip “install from a new user account” ?
    Worked for a colleague of mine who was unable to install it.
  • David Bogie
    June 15, 2006 at 9:39 pm
    Keep AE6 and 6.5, for sure.
    I am running AE7 on a last gen non-core dual 2.7 G5. It is kinda clunky compared to 6.5 on the same machine but I have very few problems.
    bogiesan
  • Sami Kaartinen
    June 19, 2006 at 8:17 am
    Now I got it working with the “New user account” -tip.
    Thanx All!
