Activity › Forums › Adobe After Effects › AE7 layers disapearing on Field Render
  • AE7 layers disapearing on Field Render
    Posted by Mark Sansone on July 28, 2006 at 4:14 pm
    Hello,
    Have an AE7 project with all layers in 3D space. RAM preview looks great. Render lower field first, and some select layers disapear. Render w/no fields, and all layers appear normally.
    Consistently the same layers. Add more layers, subtract some layers – the same images disapear. They are all stills. Have re-saved with photoshop, made sure they are RGB, still no luck.
    Work around has been to render at 60 FPS with no fields, then 200% the clip in FCP to get fields.
    Would prefer not to use this solution, and render normally with lower field first. Thoughts on what I’m doing wrong?
    -Mark
    Mylenium replied 20 years, 2 months ago 2 Members · 3 Replies
  • Mylenium
    July 28, 2006 at 4:37 pm
    Maybe you are viewing them too much flat on and they become thinner than one scanline. Other than that make sure to have enough spacial separation between the 3D layers. Even “Advanced 3D” is prone to causing clipping/ overlap errors if your layers are too close to each other.
    Mylenium
    [Pour Myl
  • Mark Sansone
    July 28, 2006 at 5:13 pm
    Legit thoughts, thanks.
    However, the images are always 90
  • Mylenium
    July 28, 2006 at 5:20 pm
    Mmh, that’s really odd, especially since they show up on higher-fps renders sans scannies. I’m afraid the only immediate solution is to realyl use that 60 fps approach you were describing.
    Mylenium
    [Pour Myl
