Activity Forums Adobe After Effects AE7: Fractional frames
  • AE7: Fractional frames
    Posted by Eric Chard on December 17, 2010 at 7:16 pm
    I’m working on an effect that relies on offsetting a duplicate of a layer in time. Unfortunately, ONE frame is too much offset.
    Is there a way to offset a layer by a fraction of a frame?
    Thanks.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Eric Chard replied 15 years, 8 months ago 3 Members · 3 Replies
  • Kevin Camp
    December 17, 2010 at 8:04 pm
    you could try increasing the frame rate for the comp (say, double it), adding keyframes on the frames that wold be the in-between-frames, then set the frame rate back and see if that gets what you need.
    i’ve not tried this, so i’m not sure if it would work, but i think it may.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Michael Szalapski
    December 17, 2010 at 9:00 pm
    What about just doubling the frame rate, offset it by one frame and then embedding that comp in a comp that’s the intended frame rate?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Eric Chard
    December 18, 2010 at 2:02 am
    Thanks fellas.
    Frankly, I was afraid that was the answer: when I’ve done similar things in the past I found it VERY easy to get confused as to what was going on. But, ::heaves sigh:: we do what we must.
    Thanks again.
