Activity › Forums › Adobe After Effects › AE7 & FCP Conflicting Frame Rates Question
  • AE7 & FCP Conflicting Frame Rates Question
    Posted by Martin Sterling on February 11, 2007 at 6:58 am
    I have footage that was shot on DVX100A camera. It was shot in F5 mode which is the 24p mode without advanced pulldown. When I Import the footage into FCP the video rate says 29.97. When I then import the same clip into AE7 the frame rate says 23.976 3:2 removal.
    Why am I getting these conflicting rates on the same piece of footage?
    THANK U IN ADVANCE
    G5 Dual 2.0 GHz processor, OSX.4.8
    Martin Sterling replied 19 years, 7 months ago 2 Members · 2 Replies
  • Aharon Rabinowitz
    February 11, 2007 at 5:00 pm
    The programs are probably not reading the meta data sotred with the video properly – that’s most likely to do with the way it’s being captured – i.e., either your video capture program or the format in which the video is being stored. The truth is there’s any number of reasons it can be happening, but if you know the frame rate – then it’s no big deal.
    In both programs you should be able to re-interpret the footage properly.
    In AE, right click on the footage in the project window, and from the pop-up choose Interpret Footage.
    Then set things properly.
    Not sure about how to do it in FCP, but I know it’s possible. You may want to check out the FCP forum or see if anyone else here uses FCP.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
  • Martin Sterling
    February 12, 2007 at 2:45 am
    thanks
