Activity › Forums › Adobe After Effects › AE7: CC Wire Removal + Motion Tracking
  • AE7: CC Wire Removal + Motion Tracking
    Posted by Boris Riabov on July 21, 2009 at 7:51 pm
    Hello,
    I have been reading CreativeCow and browsing the internet on this topic and I would love some more help. I am trying to clean up my 16mm film I shot. It can be found here for reference.
    https://www.youtube.com/watch?v=HbZ2IyQx0kg&eurl=http%3A%2F%2Fwww%2Eyoutube%2Ecom%2Fuser%2FBorisRiabov&feature=player_profilepage
    As you can see it has dirt, scratches, and verticals lines running down at times.
    I will use Film Fix to clean up the dirt and am planning to use CC Wire Removal for the verticals lines.
    1. Is there a tutorial somewhere that I can read on CC Wire Removal and how to use it?
    2. I have read about using motion tracking with CC Wire Removal. Would it be able to make my life easier so I don’t have to divided my timeline into 1000 sublips and fix each line manually?
    3. I am willing to spend the time and divide the timeline into seconds and fix each frame at a time with CC Wire Removal. I, however, do not know how to divided the timeline. Can you make each frame a subclip and fix it manually?
    Thank You
    Boris
    Jim Dodson replied 16 years, 11 months ago 3 Members · 3 Replies
  • Jim Dodson
    July 22, 2009 at 1:08 am
    CC wire removal is pretty easy to use — it stitches the scene together from the right and left of the line that you create by placing the two points.
    You can experiment with the thickness…
    In looking at your film it looks like you mostly have that one bad scratch…
    You won’t need to break the film into sub-clips because you can apply more than one instance of the wire removal effect to the same shot… — in fact, if the scratch is very thick, instead of cranking up the “thickness” (which will create a smearing/tearing effects) , try adding two or more instances of CC Wire Simple Removal and attacking the line in two (or more pieces)…
    Remember, you’ll want to key frame the two points to keep the points centered to your line– I doubt motion tracking would be very helpful in your particular circumstance… When the line disappears for a while, you can move the A&B points out of your frame; make a HOLD keyframe and just keep the points there until you need to bring them back on to your frame.
    One more suggestion, sometimes if the bottom half of the frame is dark and the top is bright (or if the thickness of the line is thicker on the top and thinner on the bottom of the frame) , you might want to handle the top half of the frame with one application of WIRE REMOVAL and the bottom half with a second instance of the effect — that way you can dial in a different “thickness” for the top and bottom… In this example the “A” point might be at the top of the frame and the “B” point might be somewhere near the middle of the frame” — and in the second instance of the WIRE REMOVAL the “A” point would be near the middle of the frame and the “B” point would be at the bottom of the frame…
    Jim Dodson
    8 Core Intel — Mac – OSX
  • Faisall Raju
    October 31, 2009 at 6:44 am
    i count remove wire in my footage,
    can you help me,
  • Jim Dodson
    October 31, 2009 at 6:51 pm
    email me at jdpix at pacbell dot net
    Jim Dodson
