Activity Forums Adobe After Effects Expressions AE2024.6.2 – Expression Removing Second Font in line
  • AE2024.6.2 – Expression Removing Second Font in line
    Posted by Lukasz Pason on November 13, 2024 at 1:52 am
    On my single line I need to use a second font for registration marks and the typeface is being removed with this expression applied to it. I can not upgrade AE and I’m not sure why the code is removing the second typeface or how to fix it.
    X = text.sourceText;
    F = Math.round(time * effect("Blink Speed")("Slider") % 1);
    L = X.length;
    T = time * effect("Speed")("Slider") - effect("Start At")("Slider") * effect("Speed")("Slider");
    Cursor = " ";
    if (F==1 | T>0) Cursor = " | ";
    if (T>=L) Cursor = " ";
    if (T>0) X.substr(0,T) + Cursor
    else Cursor
    Lukasz Pason replied 1 year, 10 months ago 3 Members · 5 Replies
  • Yoan Boisjoli
    November 13, 2024 at 2:13 am
    Hi Lukasz! So you would like to have a different font for the cursor without upgrading to the new After Effects 2025 which supports the per character expression styling?
  • Dan Ebberts
    November 13, 2024 at 2:22 am
    Unless you’re taking advantage of the new per-character styling feature in AE 2025, whenever you apply an expression to the source text property, all characters get the same styling as the first character.
  • Yoan Boisjoli
    November 13, 2024 at 2:41 am
    if you ever consider upgrading, here’s an expression that works for having 2 different fonts. I also added an option for controlling the font size of the cursor:
    var X = text.sourceText;
    var F = Math.round(time * effect("Blink Speed")("Slider") % 1);
    var L = X.length;
    var T = time * effect("Speed")("Slider") - effect("Start At")("Slider") * effect("Speed")("Slider");
    // Define the main text and cursor with distinct styles
    var baseStyle = X.style.setFont("Helvetica-Bold"); // Main font
    var cursorFont = "CourierBOLD"; // Cursor font
    var Cursor = " ";
    if (F == 1 || T > 0) Cursor = "|";
    if (T >= L) Cursor = " ";
    // Combine the text with the cursor
    var displayText = T > 0 ? X.substr(0, T) + Cursor : Cursor;
    // Apply styling
    var styledText = baseStyle.setText(displayText);
    // Apply the cursor font style only to the cursor portion
    if (Cursor.trim() != "") {
    styledText = styledText.setFont(cursorFont, displayText.length - Cursor.length, Cursor.length).setFontSize(100, displayText.length - Cursor.length, Cursor.length);
    // Return the final styled text
    styledText;
  • Lukasz Pason
    November 13, 2024 at 6:06 pm
    Got it. Thanks Dan. I’ll have to find a new approach to my setup then. We are unable to upgrade the team to the latest.
  • Lukasz Pason
    November 13, 2024 at 6:07 pm
    This is great! Thank you! I wish we could upgrade to the latest but we are locked in to 2024 at the moment.
