Activity Forums Adobe After Effects Expressions AE2020 – Change font if text includes :
  • AE2020 – Change font if text includes :
    Posted by Mathias Kalhauge on November 13, 2020 at 11:14 am
    I have a text layer that I want to change font, if a certain requirement is met.
    I currently have this expression, which changes the font of the Source text, by setting the ‘selection’ to one of two values (0 or 1):
    selection = [‘Regular’, ‘Bold’];
    fontFam = thisProperty.style.font.split(‘-‘);
    createStyle().setFont(fontFam[0] + ‘-‘ + selection[0]);
    I’m looking for an “if else” statement (or something similar) where if the Source text includes ‘:’ then ‘selection’ turns to 1 instead of 0
    Can one of the expression wizards in here see a solution to this?
    Mathias Kalhauge replied 5 years, 10 months ago 2 Members · 2 Replies
  • Trent Armstrong
    November 13, 2020 at 2:54 pm
    I left some spots where you can put your code. Just get rid of the “//” and all the code thereafter for those lines. Also, go check out https://www.w3schools.com/js/default.asp where you can find a lot of wonderful ways to use Javascript for Expressions magic.
    txt = text.sourceText;
    temp = txt.search(“:”);
    if (temp > 0) {
    //[code for : exists]
    } else {
    //[code for : doesn’t exist]
  • Mathias Kalhauge
    November 19, 2020 at 1:20 pm
    You sir are a saint!
    And I much appreciate the link. Great stuff!
