Activity › Forums › Adobe After Effects › AE & XFL for Flash
AE & XFL for Flash
Posted by Kurt Murphy on March 10, 2010 at 10:01 pmI love After Effects and don’t really love Flash. I was excited of learning AE’s better Flash export feature (XFL files). I have some questions:
Does the XFL format recognize Parents or Nulls? I’ve parented some layers to each other and to nulls – will they translate to Flash?
thanks!
kurt
Todd Kopriva replied 16 years, 6 months ago 4 Members · 10 Replies -
Todd Kopriva
March 11, 2010 at 1:40 amThe details of what is translated and how are on this page. There’s a comment from one of the After Effects quality engineers on that page that specifically addresses parenting.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Kurt Murphy
March 11, 2010 at 2:00 amThanks for responding Tod… I exported my AE project out as an AFL, but when opened it in Flash, nothing showed up… Either in the timeline nor library. I deleted the null layers, camera, and parents (leaving only illustrator files with keyframes), and still nothing showed up. Any ideas what I’m doing wrong?
thanks,
kurt murphy
Tim Kurkoski
March 11, 2010 at 2:14 amKurt – What option did you choose for Layers With Unsupported Features in the XFL settings dialog? If you chose Ignore, your .AI layers would not appear in the XFL. See the Help document that Todd linked to for an explanation.
You don’t need to delete your other layers (nulls, cameras, etc.). Just keep in mind that they don’t translate directly to Flash. AE attempts to maintain visual fidelity when exporting to XFL; that is, the appearance of your comp should be the same in Flash as it is in AE. The structure and/or number of layers may be very different, but it should look the same.
Kurt Murphy
March 11, 2010 at 2:29 amTodd,
Thanks for the response… I’m home now so I was able to experiment. I see that Flash doesn’t recognize 3D layers (so I turned them off), AND Continuos Rasterization (so I turned that off). Then I see that it doesn’t recognize ai files (unsupported file type). What DOES it recognize? I can animate in AE MUCH easier than I can in Flash. I want to keep my file sizes small so I don’t want to rasterize any 3D or effects. I was hoping that i could do this…..
thanks,
kurt
Todd Kopriva
March 11, 2010 at 2:57 am> What DOES it recognize?
Any answer that I give is just going to be quotes from the document that I linked to, since I wrote that document to answer exactly that question.
Kurt Murphy
March 11, 2010 at 4:43 amThanks Todd, one last question though – I read the ‘rtfm’ but saw no mention of illustrator, .eps, or .ai files. The beauty of this type of file is the small file size. I usually create most of the files for Flash in Illustrator for this reason. I get an ‘unsupported file type’ error when i look at the html file. I slowly found out it was from having the 3D switch on, then continuous rasterization on, then possibly trimmed layer, etc.
Please just let me know, does it not recognize Illustrator files without having to rasterize them (or do i have to save them differently)?
thank you,
kurt
Roland R. kahlenberg
March 11, 2010 at 5:42 amHeya Kurt, howzabout converting the vector files to either Shape layes or Masked solids? Just an idea.
Cheers
RoRKSell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
Todd Kopriva
March 11, 2010 at 7:00 amVectors from Illustrator aren’t preserved as vectors.
Kurt Murphy
March 11, 2010 at 2:26 pm<
> Ouch. Well, then I vote to try to remake the XFL format as something useful. I can see where Flash would render out Transfer Modes, some 3D, etc., but I use Illustrator files WITHIN Flash all the time. I really thought this might be a great solution to animating in Flash’s clunky interface.
I’ll try Roland’s good advice and convert my files to shape layers (assuming that Flash will translate those)….
thanks,
kurt
Todd Kopriva
March 11, 2010 at 3:11 pmShape layers are rasterized, too.
Exporting as XFL from After Effects is not a good way to work with vector graphics.
Here’s a link to the feature-request form.
