Activity Forums Adobe After Effects AE workflow for a former Combustion user
  • AE workflow for a former Combustion user
    Posted by Tracy Westgard on March 12, 2007 at 7:56 pm
    I would like to ask a quick workflow question. I have a music video that was shot on 16mm tansferred to D-beta and the FX shots were then sent to me. I am new to using magic bullet and AE and am fighting the urge to migrate back to combustion to do this job so I want to be clear on my path. Would I:
    1. capture at highest res I can (SDI into my suite using a decklink. 4:2:2)
    2. Then how do I remove the telecine? Or do I use magic bullet to convert to progressive frames?
    Thanks in advance.
    Tracy
    Tracy Westgard replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mark
    March 12, 2007 at 8:24 pm
    You would indeed capture at best resolution. Then bri9ng the shots into AE and in the interpret footage dialog you can tell AE to remove the 3:2 pulldown. If you edit this footage prior to bringing into AE, you may run into issues as the 3:2 order gets changed due to edits.
    You would then create a 23.976 composition. You do not need magic Bullet for this. You do your edit and fx work, then render out with a 3:2 pulldown (If you are going back out to video).
    Hope this helps,
    Mark
  • Tracy Westgard
    March 13, 2007 at 6:32 pm
    Thanks all. I am just having those pains of “OK, in C i would do it like this, but where is that little checkbox inAE????”
    Shortly after my orig post I realized that INTERPRET FOOTAGE was where I needed to be. I am using Pinnacles Rig Zapper plugin, and am loving it. The only thing that I find that is still better to go to C for is the tracker. Maybe my next play around will be importing and exporting tracking data between them.
    Anyway, thanks.
