Activity › Forums › Adobe After Effects › AE won’t re-import 6400×3600 res
  • AE won’t re-import 6400×3600 res
    Posted by Caspar Stracke on December 30, 2009 at 8:03 am
    Hello everyone,
    one day before this year ends I am facing a pretty mean obstacle with AE.
    I am working in a monster Hi res 6400×3600 and need to re-import rendered out QTs into AE.
    I am working in ProRes, all lower resolutions work when re-importng, but for the big one AE tells me “…MooV file damaged or unsupported” – both not true (I tested files)
    Also, Animation codec wont work in this size. Try to increase memory, no luck. Anybody knows a trick, or have I simply reached the max?
    Happy New Year,
    Caspar Stracke (AE CS4)
    Caspar Stracke replied 16 years, 8 months ago 3 Members · 3 Replies
  • Walter Soyka
    December 30, 2009 at 2:46 pm
    [Caspar Stracke] “I am working in a monster Hi res 6400×3600 and need to re-import rendered out QTs into AE. I am working in ProRes, all lower resolutions work when re-importng, but for the big one AE tells me “…MooV file damaged or unsupported… Also, Animation codec wont work in this size. Try to increase memory, no luck. Anybody knows a trick, or have I simply reached the max?”
    This seems to be a bug in After Effects. Quicktime supports these large resolutions, but AE won’t read them.
    You should render out to an image sequence instead; AE will have no trouble reimporting this.
    Another big benefit to rendering image sequences with hi-res projects like these is that if you make tweaks, you only need to re-render the changed frames; you can save a lot of time by not re-rendering the entire movie.
    Walter Soyka
  • Steve Roberts
    December 30, 2009 at 3:23 pm
    … and if the computer crashes mid-render (perish the thought), you only need to re-render the missing frames in the image sequence. Just a thought.
  • Caspar Stracke
    December 30, 2009 at 8:07 pm
    it worked! Walter, you made my day!
    Much thanks!
    Caspar Stracke
