Activity Forums Adobe After Effects AE won’t open a project. ID layer error
  • AE won’t open a project. ID layer error
    Posted by Mateo Mazzini on April 4, 2016 at 3:26 pm
    I have to move one project from one iMac to a macbook pro… both have after effects cc 2015, and I believe the same plugins. it is a motion graphics project plenty of shape layers, which are combined with puppet tools and stuff like that. when i open the project in the macbook pro, before it finishes loading the project, this error pops up.
    I have been going back and forth with the two machines… saving it for previous versions won´t work either.
    Anyone know any work around?
    thank you!
    Matz
    Ciji James replied 7 years, 9 months ago 3 Members · 3 Replies
  • Mateo Mazzini
    April 4, 2016 at 4:18 pm
    tried both to collect files and copy the entire project structure.. but neither seemed to work. Finally I tried checking all the layers one by one… and I realised that one plugin were used.. from boris continuum complete 8 suite. which is installed in both machines… but don´t know why.. it made the project file unusable in other machines.
    thank you!
    Matz
  • Buluce Yu
    August 20, 2018 at 2:50 am
    I had the same problems ! If you solved it,will you let me know?
    Thank you!!!
  • Ciji James
    December 22, 2018 at 6:05 pm
    Any luck on this…
