Activity Forums Adobe After Effects Expressions Ae wiggle expression jumps after start from specific time.
  • Ae wiggle expression jumps after start from specific time.
    Posted by Nuwan Thilina on November 27, 2016 at 8:57 am
    Hello there, I have added following code to my shape layer.
    This layer is animated in first 2 seconds.
    So I wanted to it to wiggle after a certain time.
    Thanks to CC, I have founded the codes that work.
    But when switching animation from key frames to wiggle there is a jump.
    wiggle start with separate value.
    How to make this transition smooth?
    Your help will be highly appreciated!
    timeToStart = 3;
    if (time > timeToStart)
    w = wiggle(1.5,30);
    [w[0],value[1]]
    else
    value;
    Nuwan Thilina replied 9 years, 10 months ago 2 Members · 4 Replies
  • Xavier Gomez
    November 27, 2016 at 3:48 pm
    You can transition smoothly between the two by using a linear or ease function:
    timeToStart = 3;
    transitionDur = 1;
    freq = 1.5;
    maxAmount = 30;
    amount = easeIn(time, timeToStart, timeToStart+transitionDur, 0, maxAmount);
    [wiggle(freq, amount)[0], value[1]];
    Note: you could also use, with the eact same result:
    timeToStart = 3;
    transitionDur = 1;
    freq = 1.5;
    maxAmount = 30;
    x1 = value[0];
    x2 = wiggle(freq, maxAmount)[0];
    [easeIn(time, timeToStart, timeToStart+transitionDur, x1, x2), value[1]];
    Xavier
  • Nuwan Thilina
    November 27, 2016 at 3:58 pm
    Wow…! This is exactly what I wanted. Spent the whole day trying to figure this out.
    Thank you so much. You saved my tomorrow. ?
    Thanks again,
    Nuwan T.
  • Nuwan Thilina
    November 27, 2016 at 4:30 pm
    One question,
    Can you let me know how to enable both axis(x,y) to animate (wiggle)
    in above expression.
    Thanks.
  • Nuwan Thilina
    November 27, 2016 at 4:44 pm
    My bad Just figured it out.
    Posted the code here. So it may help other users.
    timeToStart = 2.5;
    transitionDur = 1;
    freq = 1.5;
    maxAmount = 50;
    wiggle(freq, amount);
