Activity Forums Adobe After Effects AE warning…
  • AE warning…
    Posted by Aaron Martinez on February 27, 2008 at 7:48 pm
    hello, i have been using AE CS3 on a mac pro which has displayed some weird errors…everytime i switch apps and return to AE i get the following error
    After Effects warning: Couldn’t open Quicktime video output component.
    does anyone have an explanation for such an error?
    Jon Waters replied 18 years, 6 months ago 3 Members · 2 Replies
  • Steve Boultbee
    February 27, 2008 at 10:27 pm
    I see this error on AE 7 when switching quickly between AE and Final Cut Pro. Both apps are set to send a preview out via FireWire.
    My understanding of the error is that only one application can be using the QuickTime output component at any one time. When you switch quickly back to AE, the other application hasn’t released its hold on the Quicktime output component, and you get this error because both apps are trying to use the component simultaneously.
    Dismiss the error dialog and try moving the playhead in AE’s timeline to another frame. That should cause AE to attempt to gain control of the QuickTime output component again. Since the other app should have released the component by now, it should work.
  • Jon Waters
    February 28, 2008 at 6:12 am
    I had this error on a mac pro I was freelancing on at an agency recently.
    The tech swapped the the blackmagic card to another slot then reconfigured the slot speeds (you can change them, which I wasn’t aware of) I think it turned out to be a mother board problem though.
    I use firewire out on my own system with FCP and AE and Have not had the error pop up unless the camera is turned off and the preferences for AE are still set to send video to the firewire.
