Activity › Forums › Adobe After Effects › AE vs Combustion workflow
Posted by Steve Spaw on March 27, 2006 at 3:09 pmHi all,
I have been a combustion/3dsMAX user for many years. I do mostly broadcast and corporate ID and text/logo work. If you donChris Smith replied 20 years, 5 months ago 2 Members · 1 Reply -
1 Reply
Chris Smith
March 27, 2006 at 8:08 pmHi Steve,
In general, welcome to AE. I know how you feel. When I learned DS, I was on the DS forum asking constantly how to do this and that like AE does. They kept saying, “DS is not AE you have to think differently”. I fought but eventually listened and learned they were right.
Opposite to your preferences, I am always confused in Combustion and I hate using the Autokey function and prefer AE’s stopwatch method. I know in Combustion you have this option as well, but it does seem to be harder to deal with than AE leading many to use autokey. I don’t care for autokey because I invariably leave keys on many parameters I don’t want keyed and and forget to turn it off. This leaves me spending more time cleaning up my mess than just clicking the stop watch on the things i want moving.
So unless I’m mistaken, I don’t believe AE has an autokey function. But I guess my point is, is to try the stopwatch method. Once you get around faster, the stopwatch will be second nature. It’s a half autokey anyways because once it’s enabled any changes will add keys.
There are many short cuts to get to certain common parameters and sections. Here are a few:
r = rotaion
p = position
s = scale
t = opacity (think of Transparency)
mm = masks
u = uber key (this twirls down only parameters that have keys on them. You will use this a LOT)To twirl down multiples, hold down shift. So if you want to show scale, position and rotaion. hit S then hold shift then hit P then R.
You will get up to speed very quick.
Chris Smith
https://www.sugarfilmproduction.com
