Activity Forums Apple Final Cut Pro Legacy ? Use and Avid Raid drive for Final Cut Pro ?
  • ? Use and Avid Raid drive for Final Cut Pro ?
    Posted by Dan Billings on February 8, 2012 at 8:11 pm
    Anyone know if I could use my old Avid Raid to work in Final cut pro? The drive is VR-RTR320 (SCSI Ultra 320)and was used about 3 years ago before making the switch from Avid to Final Cut. Been just sitting on a shelf since then.
    I would think you could simply use this like any external Raid, just wipe out any old Avid files and start fresh? SCSI is a little outdated but all I would need is a card for MacPro tower.
    The real key would be making it work with a MacbookPro, but I don’t see any converters that would turn the SCSI to firewire 800?
    Dan Billings replied 14 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    February 8, 2012 at 11:39 pm
    If you can find a SCSI connector for your MacPro, it will work fine. Adapter for laptop? Nope… No firewire converters, no Express34 adapters.
    Shane
    Little Frog Post
  • Dan Billings
    February 8, 2012 at 11:52 pm
    Thanks for the info Shane.
