Activity Forums Adobe After Effects AE Unable to Export Black JPGs?
  • AE Unable to Export Black JPGs?
    Posted by Shane Newville on August 19, 2015 at 6:15 pm
    I recently update to AE CC 2015.
    I am now noticing no matter what I do I cannot get AE to
    export JPG’s that are black. I use AE to create B&W alpha
    maps for 3D model and FX texturing. If something is not
    100% black then it will not be 100% transparent.
    So I need to be able to export black.
    I’ve created hundreds of fx with this method and have not
    had this problem till recently.
    Does anyone know what changed in AE and how to get it to
    export black the way it used to?
    I even took the image into Photoshop. It looked 100% black
    but when I select half the image delete it, I can see a
    very slight difference. And Magic Wand Tool will then only
    select that area.
    HELP!! [screams like a princess in need of rescuing]
    ShaneNewville.com
    Shane Newville replied 10 years, 11 months ago 2 Members · 2 Replies
  • Walter Soyka
    August 19, 2015 at 9:11 pm
    I cannot reproduce your problem with Ae CC 2015. A pure black solid rendered to JPG remains pure black.
    Perhaps you have something going on in your comp that is elevating the black level? Can you post a project file and an output file, or at least a full-UI screenshot?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Shane Newville
    September 17, 2015 at 7:19 pm
    The sure solution I found to the problem…Revert to CC2014.
    I was running into other problems with 2015 as well. The worst
    was it would quit rendering after only a few frames. it was randomly changing the amount of frames it would render. 2015 is a bit buggy in my experience. If it runs well for you that’s great. I am not having any good luck with it though. For now, reverting solved all the above.
    ShaneNewville.com
