Activity Forums Adobe After Effects AE tutorial, i need something for this layering effect
  • AE tutorial, i need something for this layering effect
    Posted by Tyler Smith on August 14, 2010 at 4:23 am
    I want to create something using the same technique as this video, at the 10 second mark.
    https://vimeo.com/1858780
    basically a freeze frame, layers and some animation. I’m pretty new to AE and it’d be pretty cool if there were an Andrew Kramer type tutorial on this.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Grant Swanson replied 16 years, 1 month ago 3 Members · 2 Replies
  • Phil Lebeau
    August 14, 2010 at 6:11 pm
    One thing that you might have to do is to take a freeze frame of the video. Duplicate your video and you could use a mask and cut out your main character. Like in the video the guy on the snow board.
    Then you would have to rebuild the background where you cut the guy out. Like you would have to rebuild the fence and the pool. The best way would be to use photoshop and use the close tool.
    So your back layer is your background (pool and fence) and the foreground (guy) would be the top layer.
    I is probably a 3d comp as well.
    Actually Andrew Kramer has a tutorial on rebuilding a background with photoshop.
    Adding the effects can “hide” any imperfect video that is hard to cut out.
    That is about it. Someone else may have other suggestions that might actually be better, but that is how i would approach it.
  • Grant Swanson
    August 14, 2010 at 10:35 pm
    I think Andrew Kramer has two tutorials on something like this. I didn’t watch these, but I think they are what you are looking for:
    https://videocopilot.net/tutorials/time_freeze/
    https://videocopilot.net/tutorials/virtual_3d_photos/
    –Grant Swanson
    For talks and tutorials on After Effects, color correction, and film-making visit:
    http://www.VideoApex.net
