Activity Forums Adobe After Effects AE: Trapcode Form_ Map Offset missing under Qucik maps
  • AE: Trapcode Form_ Map Offset missing under Qucik maps
    Posted by Saravana Kumar on May 9, 2012 at 4:42 pm
    Hello,
    I am using AE CS4.. , recently installed Trapcode Form.. , i came to know that the option under Quick map named Map offset is missing.. ( Hav attachd the screenshot for reference) That option seems essential for the effect : Text to Sand transition…. So please help me out to FIX it .. or suggest any alternate way for that..Thanks in advance 🙂 🙂
    Dan Fredley replied 14 years, 3 months ago 2 Members · 1 Reply
  • Dan Fredley
    May 13, 2012 at 11:52 am
    It looks like an older version of Form. Go to “About” above the plugin. It probably says Form v1.x. Instead of Quick Maps you’ll have to use an animated Layer Map with a gradient on it–Text to Sand is still possible, but not as “Quick.” Find tutorials on Form 1 or buy the updated plugin.
    Dan Fredley
