Activity Forums Adobe After Effects Ae track/ SOlids into Maya (Video provided)
  • Ae track/ SOlids into Maya (Video provided)
    Posted by Jasford Muldoon on September 19, 2018 at 3:35 am
    hey guys please watch this video, its the best way to show the issue im having, which is essentially the solids are not showing up in maya, I need them to do this so I can model around them. ANy queestionas or confusion let me know. (Also I know this is more of a maya issue but nobody on any maya forum will reply to my threads
    https://www.youtube.com/watch?v=wedAUuE_HGU&feature=youtu.be
    Jasford Muldoon replied 7 years, 11 months ago 2 Members · 6 Replies
  • Eric Santiago
    September 19, 2018 at 6:07 am
    I must be out of the loop with the AE to Maya workflow.
    I thought only nulls can be accessed from AE?
    I will need to investigate this.
  • Jasford Muldoon
    September 19, 2018 at 4:00 pm
    you may be correct, any idea how i could get the soolids into maya?
  • Eric Santiago
    September 19, 2018 at 9:02 pm
    Are you using the solids as a placement for your future CG models?
    I noticed it was a lot of planar looking Solids (as in flat and wall like).
    Are you replacing or adding to the original footage?
    Example, as you drive down the street and look over to your left, a house on the video, is there but you have a CG model in front of that house.
    If it’s for placement you need to use NULLS.
    There are tutorials online that explain this in full detail.
    I’m going with past memory here.
  • Jasford Muldoon
    September 20, 2018 at 4:51 am
    Right, if you watch from this video at around 1:01 to 1:35 or so you will get the exact idea of what Im doing, Im using these solids to remodel the map “Raid” from Black Ops 2, the guy in this vid does it using cinema4d howverr and i want tot do my modelling in Maya asd it is the 3D software I like the most and want to learn. It frustrates me how easy it is for him to get his solids into c4d but for maya it seemingly impossible Eric, verry confused indeed. I may look into the Nulls idea instead if you can help me out in replicating the solids thing with nulls
    https://www.youtube.com/watch?v=k65qkSXZ3B8
  • Jasford Muldoon
    September 22, 2018 at 4:27 am
  • Jasford Muldoon
    September 27, 2018 at 4:38 pm
    OK, so i finally resolved this, what I had to do was export the after effects project into cinema4d, the export from c4d as an OBj into maya. Then in maya you will have a mesh made up of all your solids from after effects, its pretty messy… but I got the job done
