Activity Forums Adobe After Effects AE to Pro tools
  • AE to Pro tools
    Posted by Eyal Dimant on June 21, 2007 at 2:09 am
    Is there a way to export an OMF (or other split audio track type file) from after effects, to be read in a Pro Tools (I normally export OMF 2.0 from avid, with embededd media, looking to do the same with AE)
    any suggestions?
    Wes Plate replied 19 years, 3 months ago 4 Members · 3 Replies
  • Omnidecay
    June 21, 2007 at 5:05 am
    I dont think you can export an OMF without a plug (if it even exists). I would import back into Avid, then from there import to Pro Tools.
  • Roland R. kahlenberg
    June 21, 2007 at 2:10 pm
    You can Render out an OMF but I recall that there are restrictions on AE’s implementation. Check the manual and/or help files cos’ I recall seeing a writeup on the limitations.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Wes Plate
    June 21, 2007 at 11:30 pm
    The OMF export from AE is video-only.
    — Wes Plate
    Automatic Duck
