Activity Forums Adobe After Effects AE to Final Cut
  • AE to Final Cut
    Posted by Martyn Morris on November 21, 2008 at 4:34 pm
    Hi there,
    I have a project in in After Effects that needs to be rendered to QT, imported Final Cuta 16:9 project and then layed off to Digibeta.
    My After Effects comp setting is
    Preset: PAL D1/DV Widescreen
    Width 720
    hight 576
    Pixel Aspect Ratio: PAL D1/DV Widescreen (1.43) Frame Aspect Ratio: 16:9
    When the QT from AE is imported to Final Cut it imports as 4:3 and needs to be stretched.
    If anyone knows how to solve this problem I would be most grateful as the deadline is looming.
    Thanks, Martyn.
    Martyn Morris replied 17 years, 10 months ago 25,371 Members · 1 Reply
  • Martyn Morris
    November 21, 2008 at 7:18 pm
    Hi Dave,
    thanks for the advice, clicking the Anamorphic colum did the trick.
    Thanks for your speedy response, its saved me a lot of time.
    Martyn.
