Activity Forums Apple Final Cut Pro Legacy AE to FCP codec question
  • AE to FCP codec question
    Posted by Dan Hayes on May 4, 2009 at 10:25 pm
    Hi All,
    I need the wisdom of the crowd on this.
    The situation:
    I cut a offline for a green screened, graphic intensive, 1920×1080 spot, sent the edl to the motion graphics artist who is composting the entire the entire thing in After Effects and will export the completed 60 seconds for me to lay back the audio and master to tape in FCP.
    The question:
    What’s the best codec for him to use for the final render so that we can avoid gamma/color shifts resulting from the whole “AE operates in RGB/FCP in YUV” situation? I don’t have to drop the finished composite into an existing sequence and match what’s there, I just want what I’m seeing to match what he was seeing as close as possible.
    Dan
    Jeremy Garchow replied 17 years, 3 months ago 2 Members · 2 Replies
  • Dan Hayes
    May 4, 2009 at 10:51 pm
    It was shot with a RED camera at 3840×2160. The compositor does not have FCP on their system.
    Dan
  • Jeremy Garchow
    May 5, 2009 at 4:17 am
    Can your system handle Uncompressed 10bit 1080i footage? if so, that’s the way I’d go if the AE guy doesn’t have ProRes.
    Jeremy
