Activity Forums Apple Final Cut Pro Legacy AE to FC: animation or DV?
  • AE to FC: animation or DV?
    Posted by Perry Leenhouts on June 30, 2008 at 4:42 pm
    I’ve been digging through posts on the cow, but now I’m even more confused, hope somebody can enlighten me on this one:
    For an NTSC broadcast my final output medium will be a DVCPRO tape.
    -I started in After Effects, rendered the animation in Quicktime/8bit-Animation-100%/field render OFF.
    -I imported the file into Final Cut, and put it on the timeline. (In this case, I basically use FC as a player, exporting the video through firewire to DVCPRO.)
    -sequence settings: DVCPRO/RGB/best/lower fields first
    Is this the best possible workflow? Should I render from AE in 16bit?
    Thanks in advance,
    Perry
    Chris Borjis replied 18 years, 2 months ago 3 Members · 3 Replies
  • Eric Wais
    June 30, 2008 at 5:14 pm
    For broadcast DV 8-bit is fine – it’s FCP’s native uncompressed format so everything plays on the fly. You can use Animation or None but you end up having to render and re-render everything in FCP. If you’re REALLY worried about quality you can use DV 16-bit but it’s not neccessary and will slow down your workflow in FCP if you need to do any further finishing to the final sequences. Once everything’s encoded to tape there isn’t any difference.
  • Perry Leenhouts
    June 30, 2008 at 5:38 pm
    Thanks a lot & thanks for the quick reply!
  • Chris Borjis
    June 30, 2008 at 10:16 pm
    [Eric Wais] “For broadcast DV 8-bit is fine – it’s FCP’s native uncompressed format so everything plays on the fly. You can use Animation or None but you end up having to render and re-render everything in FCP. If you’re REALLY worried about quality you can use DV 16-bit but it’s not neccessary and will slow down your workflow in FCP if you need to do any further finishing to the final sequences.”
    DV is a HIGHLY compressed 8-bit only format, where can you set it to have a depth of 16-bits?
    Are you talking about the Audio being 16-bit?
    The best thing to do is to bring it in as animation and render it with the DVCPRO-50 codec if it really is going to DVCPRO tape. That way it will still look better than NTSC DV by itself.
