Activity Forums Adobe After Effects AE to AVID Express Pro export problems
  • AE to AVID Express Pro export problems
    Posted by David Seay on February 13, 2006 at 4:45 pm
    Some, not all of my AE effects look awful when imorted into Express Pro. They are beautiful in AE. I have a composition with lots of right to left movement in it and the images and graphics are almost unreadable when imported into AVID because of jittering. I read that side-to-side movements are difficult for AVID to handle. Is this correct.? If so, anyway to work around it?
    I have tried every possible import/export combination- field order, frame blending, motion blur, non-interlaced import, etc, etc. Am I missing anything? These settings work great for other compositions. If it matters, I’m using all PSD files to build the comp with.
    Here are my import/export settings:
    After Effects Export:
    render settings:
    Quality – best
    resolution – full
    frame blending – on for checked layers
    field render – off
    motion blur off
    output module:
    Animation Codec; millions of colors; 29.97fps
    comp side – 720 x480
    spatial quality 100
    no cropping
    RGB; Millions of colors: premultiplied (matted)
    AVID Import:
    Aspect Ratio: 601 non square
    Color Levels: RGB
    File Field Order: Lower field first
    Alpha: ignore
    Resolution DV 25
    Mylenium replied 20 years, 7 months ago 2 Members · 1 Reply
  • Mylenium
    February 13, 2006 at 5:47 pm
    No wonder. Why are you exporting sans fields from AE if you are working with fields in Express? Express Pro will simply double your frames to generate fields from them which of course gives stuttering movement.
    Mylenium
    [Pour Myl
