Activity › Forums › Adobe After Effects › AE to Avid best way?
Posted by Rotem_n on July 17, 2006 at 5:05 pmThe situation:
I need to transfer rendered files from my graphics suite over to the Avid suite.
IRotem_n replied 20 years, 2 months ago 4 Members · 4 Replies -
Lars Bunch
July 17, 2006 at 6:12 pmHi,
I frequently render files out for use in an Avid. I use the Avid Meridian codec which requires the files to be 720×486. (The codec can be downloaded from Avid’s site.) Our Avid Symphony bays are Mac based and we have had no problems with picture quality with this work flow.
If your comps are 720×480 there may be artifacting when the Avid converts the file to a 720×486 Meridian file.
Also make sure that the editor isn’t compressing the animation as it is brought into the Avid as that will definitly cause artifacts.
Hope this helps,
Lars
Adolfo Rozenfeld
July 17, 2006 at 7:45 pmYou don’t have to export Quicktime movies anymore (unless you need things like embeded alpha channels, for instance).
I think it was AE 6.5 the one that added the ability to export native AVID OMF essence files, ie, just like the ones AVID systems use to capture and edit. You can just export an OMF file, and the AVID system will be able to use it without transcoding. At least that’s how I understand it. You have settings for 1:1 uncompressed, DV, interlaced or progressvie, etc.
Hope this helps.Adolfo Rozenfeld
Buenos Aires – Argentina
https://www.adolforozenfeld.com
adolfo(AT)adolforozenfeld.com -
Dan O’brien
July 17, 2006 at 9:40 pmAlso make sure the editor’s import setting are the same as the settings you’re rendering out with (field order, etc). I know movies imported with the wrong field order have caused some of my quicktimes to look really bad in Avid.
