Activity Forums Adobe After Effects Ae to AME problem
  • Ae to AME problem
    Posted by Peter Brelan on December 11, 2016 at 9:55 am
    Hello everyone
    when I send a comp from AE to AME, the rendering in AME is really, really slow (hours and hours)
    If i export “lossless” from AE and add the exported media in AME, the exportation works very well.
    Do you have any idea why? I need to export directly in AME.
    Thank you
    Pierre
    Peter Brelan replied 9 years, 9 months ago 2 Members · 2 Replies
  • Roei Tzoref
    December 11, 2016 at 11:06 am
    exact Ae version?
    note that if you send directly to AME then it rendering and encoding one after the other so you should calculate your total render time of course for comparison (if you haven’t already). even it total, it’s actually sometimes a bit slower than rendering first, and then manually dragging the rendered file to AME but not by much.
    if after reading this it’s still an issue:
    1. try resetting your AME preferences by holding shift as you launch it (there is no dialog screen)
    2. under general preferences try to change the renderer and see if you get better performance CPU vs GPU
    3. test a simple clean project with a few simple layers and see if this is the case too. isolate the problem as much as you can
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Peter Brelan
    December 11, 2016 at 10:16 pm
    Thank you Roei,
    I tried with another project and the export works ok with all the same preferences in AME.
    I’ll try to clean the project that doesn’t work.
