Activity Forums Adobe After Effects AE text to particle dust
  • AE text to particle dust
    Posted by Eric Jordan on September 29, 2006 at 9:42 pm
    I am trying to achieve the following effect: I want to break up AE text elements into dust particles that will then be attacted to a surface. Anyone have any suggestions for a plugin that can disolve text into several tiny particles that are somehwat controllable on an animation level?
    Thanks to anyone who can help…
    Roland R. kahlenberg replied 19 years, 12 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 30, 2006 at 1:23 am
    There’s a COW tutorial that does this trick – minus the particles landing onto a surface. For that bit, you’ll need particle playground. Checkout my COW tutorial, particle playland, which covers Kinetic Friction. You’ll need Kinetic Friction to have the particles land on some part of your comp. Blowing up the text requires you to use either Layer Exploder or Particle Exploder, depending on how you input your text. This bit takes some time to render.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
