Activity › Forums › Adobe After Effects › AE should be faster… right.
  • AE should be faster… right.
    Posted by Travis Wermedal on September 22, 2009 at 7:00 pm
    I am running CS4 on my quad-core mac. I just upgraded to 14GB of RAM so I feel like AE should be running a lot faster than it is. I am working with a 3D project that consists of only text (but a ton of it) and when I move the playhead it takes a good 5-7 seconds to display the frame, which makes it virtually impossible to edit.
    I have the Render Multi frames checked with minimum allocation set at 2.09, and the slider to the left…
    Foreground 1.79gb
    Background 8.36gb
    Also, how does the disk cache effect speed?
    And how high should I set the max. disk cache?
    Any help would be greatly appreciated as to how to set up my machine more optimally. THANKS A BUNCH.
    Erik Lindahl replied 17 years ago 5 Members · 4 Replies
  • Simon Bonner
    September 22, 2009 at 7:06 pm
    It does sound a little slow for just text, but I guess if you have lots of different layers… At the risk of sounding obvious, you might want to work with the resolution at 50% or lower, with blur effects (like camera depth of field) turned off, and perhaps with pre-rendered layers (e.g if you have finished working on a number of layers, render just those layers out and then reimport them – you can always switch out for the original layers when you do your final render if you prefer).
    Simon Bonner
    youtube.com/simonsaysfx
  • Brian Charles
    September 22, 2009 at 7:15 pm
    Are you using Motion Blur and lights? Those can slow frame preview dramatically. Is OpenGL on? That can speed up 3D previews.
    Additional RAM doesn’t really increase working speed, just gives you longer RAM previews and allows you to use multiple cores when rendering. I’m on a dual quad-core mac with 16GB of RAM, a similar configuration to yours.
  • Todd Kopriva
    September 22, 2009 at 7:47 pm
    First, make sure that you’ve updated to After Effects CS4 (9.0.2). There were a lot of performance improvements in that update.
    Second, check out the many tips on improving performance here.
    You ask about the disk cache. See this page. The disk cache doesn’t affect RAM preview, by the way.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Erik Lindahl
    September 23, 2009 at 11:19 am
    Two things that will bog your rendering / preview speed down are:
    1. Working in greater than 8-bits
    2. Working with a color managed project
    No 1 is pretty obvious why it will make things render slowly.
    Why no 2 makes life unbearable in AE I’d personally like to know. The speed hit is just to high for me to be able to use that. Even after a render is done the screen refresh is dog slow (in combination with the speed hit video-output over the video-card get’s, this is amazingly slow).
    But yeah, in general, working with 3D layers in AE with DoF effects, lights, shadows etc is dog slow. The end result can be really nice, but you need patients to say the least.
    Erik Lindahl
    Freecloud Communication
