Activity Forums Adobe After Effects AE / Shifting Audiofile on Sample
  • AE / Shifting Audiofile on Sample
    Posted by Bogdan Brak on October 22, 2012 at 10:34 am
    Hey guys.
    got CS6 here… and I’m puking a square right now.
    Is there a possibilty IN After Effects to shift an audiofile some milisecs or some samples to the left/right?
    It’s always jumping to the next or previouse frame… this is totally useless.
    Would appreciate your help.
    Thanks in advance.
    Bogdan Brak replied 13 years, 10 months ago 2 Members · 2 Replies
  • Vishesh Arora
    October 22, 2012 at 2:56 pm
    Bogdan
    I have found a trick to do this but its a lit bit complicated.
    1. Select your audio Layer and Press ” Cmnd/Cntl + Alt/Opt +T “ to enable time remapping.
    2. Now Open your graph editor and select Time Remap property. You will see a linear graph.
    3. Disable the Snap button(Magnet shape) which is below the graph in the graph editor.
    4. Now drag and select the Two end points of your Time Remap graph where you want it.
    5. Now Enable your time line. Select your audio layer and stretch the In and Out Point of Audio Layer(or make it of comp length)
    6. Press ” L” “L “ and You will see that your waves are now in between frames.
    May be this will work. A long and complicated method 😀
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Bogdan Brak
    October 22, 2012 at 6:05 pm
    Thanks…
    got to check it out tomorrow.
