Activity Forums Adobe After Effects AE Shatter Gradient
  • AE Shatter Gradient
    Posted by Eric Sanderson on August 22, 2011 at 7:21 pm
    In what situations will using a gradient layer for shatter NOT work. Im not getting any result here and i dont see any reason why i shouldnt be:
    I have the shatter effect on the layer i want to shatter obviously, using a pre-comped colorama fractal noise for the custom shape. and have another pre-comped gradient ive selected to use for the shatter, tolerance is 100%, ive tried inverted and not even though i know it shouldnt be inverted, just not getting any result AT ALL. Any ideas?
    Walter Soyka replied 15 years ago 2 Members · 3 Replies
  • Eric Sanderson
    August 22, 2011 at 7:24 pm
    And if i specify i want a gradient to initiate the dynamics, why do the forces still affect it too? Obvisouly i just too size and strength down so that didnt but is that part of my problem?
  • Eric Sanderson
    August 22, 2011 at 7:35 pm
    Nevermine, im just realizing theres not time sampling for the gradient layer, which is too bad kind of eliminates a lot of the benefits of using a gradient map. Looks like animating the tolerance will get me close but really wish it would accept the animation of my gradient itself. If anyone knows how that would be great (without using a force)
  • Walter Soyka
    August 22, 2011 at 9:07 pm
    [Eric Sanderson] “Nevermine, im just realizing theres not time sampling for the gradient layer, which is too bad kind of eliminates a lot of the benefits of using a gradient map.”
    That’s because Shatter is a physical simulation: you set up the initial conditions, then Shatter handles all the physics to generate the results.
    What effect is it that you’re looking to achieve?
    Walter Soyka
