Activity Forums Adobe After Effects AE scrolling text
  • AE scrolling text
    Posted by Richard Chenoweth on December 20, 2008 at 7:07 pm
    I am trying to make four minutes of scrolling text in AE (CS3) at 720 x 480.
    The text scrolls from +400 pixels down to -10,400 pixels in the “position” animator.
    When rendering, AE runs out of memory about 1/5 of the way in. I have gone to prefs and assigned
    Disk Cache at 100,000 MB on an empty 640GB HD in my MacPro. I left other memory prefs at default.
    Is it possible to render four minutes of DVD quality text or is this just impossible?
    Thanks all!!
    Richard
    Kevin Camp replied 17 years, 9 months ago 2 Members · 1 Reply
  • Kevin Camp
    December 22, 2008 at 12:05 am
    it sounds like ae is having trouble clearing the ram cache. there’s 2 things you should try, one is to choose edit>purge>all from the menu prior to rendering, this will clear the ram cache prior to rendering. the other is a ‘secret’ pref that you can set to force ae to clear the cache at specific intervals and often helps in cases like this.
    to get the secret pref, hold the shift key down while selecting any preference, like shift+preferences>general. then, from the preference window, click the prefernce dropdown menu to change preferences. at the bottom should be one called ‘seecret’. select it and then set the ‘purge every xx fames’ to a number that is less than where ae stops rendering (ie. if it fails to render at frame 103, set it to 80-90).
    note that you will want to set it back to zero when you are done with this project, purging the cache at set intervals can reduce performance and should only be used in cases like this…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
