Activity › Forums › Adobe After Effects Expressions › AE Scripting: trying to edit text in a layer
  • AE Scripting: trying to edit text in a layer
    Posted by Rob Packer on November 9, 2021 at 1:12 pm
    I’m new to scripting in AE. So far have managed to create a dialog and get input, copy layers from another composition, copy the sourceText from that layer and make layers visible. I have text from an edittext field. In another script it can be set as the sourceText.
    I cannot seem to combine the imported layer text with the edittext field. Both are string values, so I am confused.
    The script included starts after the dialog declaration. This is the last piece in a bigger script.
    // assign values to the relevant compositions & setup global variables
    var compList = app.project.item(1); // composition with the list of cameras
    var compEditing = app.project.activeItem;
    var focalLen = “”;
    var zoomLen = “”;
    function setLens(){
    focalLen = ” @ ” + focalLength.text + “mm”;
    if(lens1.value == true){
    app.project.item(1).layer(11).copyToComp(compEditing); // layer 11 has the needed text
    var zoom = compEditing.layer(1).text.sourceText.value; // get text from the imported layer
    alert(zoom); // display the imported layer text
    // zoomLen = zoom + focalLen; // combine imported layer text with the focalLen text – fails here
    alert(zoom + focalLen); // display the focallen text – this also fails
    // alert(zoomLen); // display the combined impoted and focalLen text
    compEditing.layer(1).property(“Source Text”).setValue(zoomLen); // set the text for the layer to the combined value
    compEditing.layer(1).enabled = true;
    dialog.show();
    dialog.center();
    Any help would be appreciated.
    Blessings
    Rob
    Rob Packer replied 4 years, 10 months ago 2 Members · 2 Replies
  • Andrei Popa
    November 9, 2021 at 2:00 pm
    Hi Rob.
    Replacce var zoom = compEditing.layer(1).text.sourceText.value with var zoom = compEditing.layer(1).text.sourceText.value.text.
    Your code returns a variable that is of type TextDocument, not string. That variable also contains font, fontSize, fontFamily, text and other data.
  • Rob Packer
    November 9, 2021 at 9:26 pm
    Thanks Andrei!
    I figured it was something simple It works perfectly now.
    Rob
