Activity › Forums › Adobe After Effects Expressions › AE Scripting: Change value of a variable?
  • AE Scripting: Change value of a variable?
    Posted by Kevin Snyder on April 20, 2020 at 7:24 pm
    Is it possible to change the value of a variable based on whether or not the property is from an effect? Here’s what I’m trying, but I don’t get a change in value when selecting an effect property.
    var myProp = selectProps.isEffect;
    if (myProp == "false") var T = "cat";
    else var T = "dog";
    Kevin Snyder replied 6 years, 5 months ago 2 Members · 4 Replies
  • Dan Ebberts
    April 20, 2020 at 8:25 pm
    When you do this:
    myProp will be a boolean, so then you can do this:
    var T = myProp ? “dog” : “cat”
    or, closer to the way you were doing it:
    if (myProp)
    var T = “dog”
    else
    var T = “cat”;
    In any case, you don’t need to do this:
    if (myProp == “false”)
    you would do this instead:
    if (! myProp)
    or, if you insist on doing it that way, at least lose the quotes:
    if (myProp == false)
    Dan
  • Kevin Snyder
    April 20, 2020 at 9:04 pm
    Thanks, Dan.
    So I’m using the code below. From my understanding, if the property is from an effect var myText = “dog” and if the selected property isn’t from an effect var myText should be “cat”? Is that the correct assumption? For some reason, it always returns as “cat”.
    var myText = myProp ? "dog" : "cat";
  • Dan Ebberts
    April 20, 2020 at 9:50 pm
    If the selected property is the effect itself (not if it belongs to an effect) you should get “dog”.
    Dan
  • Kevin Snyder
    April 21, 2020 at 3:47 am
    Gotcha, that makes sense. Thanks.
