Activity Forums Adobe After Effects Expressions AE Script to emulate Drag Audio on New Composition icon To create composition
  • AE Script to emulate Drag Audio on New Composition icon To create composition
    Posted by John Gate on September 9, 2020 at 5:50 pm
    Hi there,
    If we drag an audio clip from project panel and drop on composition icon, then it creates a composition with audio in it.
    How can i get the same behavour using a script?
    Please advise
    Walter Soyka replied 6 years ago 2 Members · 1 Reply
  • Walter Soyka
    September 10, 2020 at 4:25 am
    Yes, and it’s pretty straightforward if you’re familiar with scripting. Here’s some commented code:
    // create an undo group so we can Control+Z this all away app.beginUndoGroup("Create new comp with first selected footage");
    // assume the first selected item in the project panel is our audio footage. // in real life, you'd already have an object for this. // note that I'm not doing any error checking here, so things will go wrong if you don't have a valid selection var audioTrack = app.project.selection[0];
    // create a new comp named after our audio track, 1920px wide, 1080px high, square pixels, at the length of the audio track, and at 29.97fps var newComp = app.project.items.addComp("Comp " + audioTrack.name, 1920, 1080, 1, audioTrack.duration, 30000/1001);
    // add the audio footage as a layer in the new comp var newAudioLayer = newComp.layers.add(audioTrack);
    // close the undo group, that's all, folks! app.endUndoGroup();
