Activity Forums Adobe After Effects Expressions AE Script “Else” isn’t working
  • AE Script “Else” isn’t working
    Posted by Kevin Snyder on September 14, 2020 at 5:46 am
    I’m trying to create a script that will run different functions based on input (yes/no) from the user. I can get either set of functions to work, but I can’t get them both to work based on the user’s input. If true (third line), the script will run the functions of child and proximity. If I set it to false, it will run the function custom. For some reason, yes or no is running the same set of functions. Here’s the code:
    app.beginUndoGroup("Proximity");
    if (confirm("Standard transform properties?"));
    if (true){
    function child(){
    var myComp = app.project.activeItem;
    var scriptFolderPath = File($.fileName).path;
    var colorFolderPath = scriptFolderPath + encodeURI("/preset");
    var ffxFile = new File(colorFolderPath + encodeURI("/Proximity Child.ffx"));
    myComp.applyPreset(ffxFile);
    child()
    function proximity(){
    var controller = app.project.activeItem.layers.addNull();
    controller.name = "proximity";
    controller.enabled = true;
    var ffxFile = new File(colorFolderPath + encodeURI("/Proximity Master.ffx"));
    controller.applyPreset(ffxFile);
    proximity()
    else
    function custom(){
    var ffxFile = new File(colorFolderPath + encodeURI("/Proximity Custom.ffx"));
    custom()
    app.endUndoGroup();
    Kevin Snyder replied 6 years ago 2 Members · 2 Replies
  • Stephen Dixon
    September 14, 2020 at 6:02 am
    That’s not how if()-then commands work. The syntax is
    if (expression-that-evaluates-to-true-or-false){doStuff()}else{doOtherStuff()}
    Your code has if(true) on the third line, and since true is the javascript constant boolean true the condition will always evaluate to true, so the first block of code will get executed.
    get rid of the semicolon on line 2 and all of line 3 and it should work.
  • Kevin Snyder
    September 14, 2020 at 3:33 pm
    Great! Thank you. That works.
