Activity Forums Adobe After Effects AE script create a new composition from a sequence of images
  • AE script create a new composition from a sequence of images
    Posted by Tania Situm on October 1, 2015 at 5:35 am
    Hi everyone,
    I am writing a script for a network rendering on multiple machines. Therefore, I need to write a script that would create an After Effects composition from a sequence of images (photoshop sequence which is imported back after rendering). I can do it manually by dragging my sequence to the “create a new composition” button or by right clicking on the sequence but I want to automate the hole process.
    Would this be possible using After Effect scripting? I didn’t find any information in the AE scripting guide…
    Regards,
    Tania Situm
    Tania Situm replied 10 years, 7 months ago 2 Members · 3 Replies
  • Walter Soyka
    October 1, 2015 at 12:38 pm
    If you change your post-render action to “Set as proxy,” you can just add the the original comp to the render queue twice; once for the network render, then a second time for the image-sequence-to-movie stitching, with custom render settings where proxies are on.
    I don’t think you can create a new comp from the footage directly via scripting, but you can create a new empty comp with the correct settings for the image sequence, then add the image sequence to it.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Tania Situm
    October 5, 2015 at 9:05 am
    Thank you so much Walter, works perfectly for me!
    However, I don’t know if it’s linked but I just noticed that my two rendering machines aren’t really rendering as they’re always “skipping” files. Now if I render my project with both of my rendering machines it takes the same time as if it was rendered by only one single machine (no network rendering). Is there any setting I forgot?
    My computers specs:
    Windows Edition – Windows Server 2012
    Processor – Intel(R) Xeon(R) CPU E-62666 v3 @ 2.90GHz 2.90GHz
    RAM 15.0 GB
    System 64bits
    Thank you for your answer.
    Tania SITUM
  • Tania Situm
    October 7, 2015 at 4:03 am
    Finally found what’s wrong, in Preferences > Memory & Multiprocessing “Render Multiple Frames Simultaneously” option was ticked!
    Tania SITUM
