Activity Forums Adobe After Effects AE says project file “doesn’t exist”
  • AE says project file “doesn’t exist”
    Posted by Jon Doughtie on December 14, 2017 at 3:16 pm
    I have a Motion Array template I have customized for a particular project, saved as a different filename to preserve the original template.
    The customized version has been opened and used in AE 2017.2 previously without issue.
    Now when I attempt to open it, AE gives an error message – it indicates the filename (correctly stating the entire file path) “doesn’t exist”. The file is ever so clearly there.
    Corrupted file? Any ideas?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
    Juntao Dai replied 7 years, 11 months ago 3 Members · 3 Replies
  • Michael Szalapski
    December 15, 2017 at 2:40 pm
    Do you get the message when you double-click the file itself only or do you also get it when you go to the File>Open command?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Jon Doughtie
    December 15, 2017 at 7:31 pm
    It was happening with either approach, but not a deal-breaker anyway. I just went back to the template and re-made the file. Problem gone.
    System:
    Win 7 64-bit
    32GB RAM
  • Juntao Dai
    October 3, 2018 at 7:19 pm
    I meet the same problem with ae 2018.3 on win10
    Finally i find out one of my fold in the file path has two blanks.
    Rename the wrong folder , your project will come back!
