Activity › Forums › Adobe After Effects › AE rotscope & Tracing
  • AE rotscope & Tracing
    Posted by Accountfrozen_needsrealnameupdate_here on June 4, 2008 at 7:55 pm
    Hi All
    I am trying to create an effect on a clip of a bride holding the bouquet in Black & white and keeping the bouquet in color. i know how to do this in photoshop but it is trickiyin AE due to the shot zooming wide. i masked out the bouquet but am having troble keeping it in scale and position. any help would be greatly appreceiated.
    AE 6.5
    Thanks G
    Joey Foreman replied 18 years, 3 months ago 2 Members · 1 Reply
  • Joey Foreman
    June 5, 2008 at 10:08 pm
    You might want to play around with the Leave Color effect. If the color of the bouquet is not found anywhere else in the shot you might get an acceptable result. If it is, you could duplicate the layer and apply the HSV effect to the bottom layer. Then animate a junk matte around just the bouquet on the top layer. Apply leave color to the top layer and animate its value. Animate the value of the HSV effect on the bottom layer to be in tandem with Leave Color on the layer above. You might be able to connect the two effects via an expression.
    Hope that helps.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
