Activity Forums Adobe After Effects AE Resolution Size
  • AE Resolution Size
    Posted by Dan Hashemi on November 5, 2010 at 2:49 am
    So I shoot in full 1920×1080 resolution with a 7D @ 24fps…this maybe a simple question, but in AE, is it better to be editing at this same resolution level, or should I be reducing and later expanding so that the render times are so grueling?
    If I’m not mistaken, for motion graphics applied to video clips, I should be editing the clip at its full resolution…but for animation/typography/etc. such as title sequence intros and so on, can I do it in a smaller size and then scale up once imported into Premiere or is that not recommended?
    Main issue is that at 1920×1080, the render times while working take forever! I’m on a MBP, 2.4Ghz, 4GB RAM.
    Dan
    Dan Hashemi replied 15 years, 9 months ago 3 Members · 3 Replies
  • Todd Kopriva
    November 5, 2010 at 6:08 am
    Work at the pixel dimensions of the largest output that you’re likely to create. That way, you won’t have to do any scaling.
    Scaling of pixels always loses quality, in any application, so it’s best to avoid it. Scaling down loses less quality than scaling up.
    When it comes time to render and export, create your master at the original size of your composition, and you can also crop and scale as needed to create smaller output versions.
    See this page for more on planning you work.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Simon Bonner
    November 5, 2010 at 10:17 am
    Dan,
    You might like to watch some tutorials on using proxies (lower resolution copies of your original assets that are easier to work with before you decide to render). You can always turn off intensive effects like grain and blur whilst working, or work at a lower res. But like Todd says, there’s no point rendering at a lower res and then upscaling, regardless of the type of project you’re working on. It will look nasty.
    Simon Bonner
    youtube.com/simonsaysfx
  • Dan Hashemi
    November 5, 2010 at 10:24 pm
    Now you’ve convinced me to go up to 8GB 🙂
    Sorry, I did mean 23.973…it was just easier to type 24, lol!
    Thanks for the response though! Much appreciated and great insight!
    Dan
