Activity › Forums › Apple Final Cut Pro Legacy › AE renders not coming in anamorphic
Posted by Jason Brown on August 26, 2009 at 5:20 pmWhat do I need to do to interpret After Effect renders (ProRes 444 codec) with the correct PAR? I’m having to checkbox the “anamorphic” checkbox after import.
-Jason
Jason Brown replied 17 years ago 3 Members · 8 Replies -
David Roth weiss
August 26, 2009 at 5:25 pmThat’s not nearly enough info Jason… We’re not there to look over your shoulder, so how do we know what format you’re working with in FCP or what you’re rendering out of AE?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Jason Brown
August 26, 2009 at 5:37 pmHey Thanks David, as I said
“After Effect renders (ProRes 444 codec)”As far as what I’m working with in FCP…it shouldn’t matter…I’m not referring to anything in my timeline…and I’m importing a clip…so it’s completely independent of any SEQ settings.
But here it is: Format in FCP –
timeline = NTSC DV anamorphic
timeline codec = NTSC DVFormat in AE – ProRes 444 (to make use of realtime alpha)
-Jason
Jeremy Garchow
August 26, 2009 at 5:42 pmYou have to check the anamorphic box as there’s no metadata tag in the QT dialog to tell FCP otherwise.
Jeremy
David Roth weiss
August 26, 2009 at 5:46 pmPixel Dimensions would have helped, as ProRes 444 can be SD or HD and I wasn’t sure if that was an issue.
David Roth Weiss
Director/Editor
Jason Brown
August 26, 2009 at 5:53 pmGreat…thanks Jeremy.
But how when I open a clip digitized by FCP in AE, it recognizes the 1.2 PAR? That would mean there is metadata in the QT file. Right?
Jason Brown
August 26, 2009 at 5:55 pmI gotcha…sorry. I’ll try to be more clear in the future.
You and Jeremy have answered a ton of questions in the past for me…so I really appreciate the time you guys take. I’m coming from AVID and I really feel that having Media Composer as a second option is really a good idea. There are some real shortcomings with FCP…but some things that blow AVID out of the water…it’s fun learning all this new stuff!
-Jason
Jeremy Garchow
August 26, 2009 at 6:00 pm[Jason Brown] “But how when I open a clip digitized by FCP in AE, it recognizes the 1.2 PAR?”
Becuase that metadata is in the QT file, yes, as you captured it that way in FCP. But when writing back from AE, that metadata does not get stored in the new file, unfortunately.
Jeremy
Jason Brown
August 26, 2009 at 7:30 pmGood info. Thanks…
While you are helping me. I can’t in in the manual. Is there a way to actively scrub audio without going into “audio scrub” mode? like hold down a modifier as you are dragging to scrub?
