AE renders different than Media Encoder
Hi! I recently made a video for a job using 3D camera tracker and a couple of 3D text layers, all was good until I rendered and the result was some terrible-looking choppy text, I dropped the project on Media Encoder and the result was much better, just as I had seen it in the AE preview.
I made a test video to show what I’m talking about.
This is the test video rendered with Media Encoder: https://youtu.be/JLHTjYCOFSM
And this is a comparison between the two: https://youtu.be/c4uBHfFmhcwIf you watch in HD you’ll notice that the right-hand side text moves very strangely, also the colors are slightly off, the Media Encoder version looks just like the preview in AE.
The settings I used were for both were
Codec H.264
Resolution: 1920×1080
Frame rate: 29,97fps
VBR 1 Pass, target: 32Mbps, max 40MbpsWhy is this happening? any clue?
