Activity Forums Adobe After Effects AE Rendering different than Preview
  • AE Rendering different than Preview
    Posted by Byron Fillmore on February 7, 2012 at 6:43 pm
    When I preview my movie it looks great. I am apply some effects on the movie to soften the skin of the person in the clip. Everything looks great.
    When I render the movie it ignores the effects I have applied to the movie and looks terrible.
    Can anyone give me any advice as to why this is happening?
    I am desperate.
    Thank you
    Byron Fillmore replied 14 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Byron Fillmore
    February 7, 2012 at 7:36 pm
    I read earlier post from this board and made sure it is off.
    I have figured out that it will not render as expected unless I render at 50%…it looks great when I do this… which is disappointing as I want the full resolution of the video.
    Does this make any sense?
    Thanks for your quick reply.
    Byron
  • Michael Szalapski
    February 7, 2012 at 7:43 pm
    If Dave’s suggestion doesn’t fix it, we’re going to need a lot more information: specs of your computer, version of After Effects, format and codec of your footage, the format and codec into which you are rendering, etc.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Byron Fillmore
    February 7, 2012 at 7:53 pm
    Computer:
    Intel Core i7 CPU 960 @ 3.2 GZ
    24 GB RAM
    64-Bit OS (Windows 7 Pro)
    After Effects CS 5.5 (10.5.0.253)
    Footage:
    Shot from Canon 5D Mark II
    H.264 (1920×1080)
    Rendering:
    F4V
    The effect I am using on the video is from this tutorial.
    https://www.diymusicvideo.com/2011/08/face-blemish-removal-in-after-effects/
    I’ve basically duplicated the footage on a new layer and use an adjustment layer to render the smooth skin on the person in the clip.
    When I render @ 100% the effect basically disappears. If I render @ 50% it works fine. Any suggestions? Thanks in advance!
  • Byron Fillmore
    February 7, 2012 at 8:25 pm
    Would Premiere Pro suffice or do you think I should use a non-Adobe product?
  • Byron Fillmore
    February 7, 2012 at 8:56 pm
    I tried the suggestions above and I am getting similar results.
    Any other suggestions?
    Thanks in advance.
    Byron
  • John Cuevas
    February 7, 2012 at 9:48 pm
    Or ost a couple of pictures, which you can do at the cow. 3rd icon from the right in the reply box
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Byron Fillmore
    February 8, 2012 at 2:16 pm
    Here is a screenshot of the changes to the video clip when I view @ “Full” and @ “Half”
    Any ideas? Thanks again!
