Activity Forums Adobe After Effects AE rendering AAAAAAAAAAARGG!!!!!
  • AE rendering AAAAAAAAAAARGG!!!!!
    Posted by Dannica Clayton on April 30, 2009 at 2:47 am
    hey hey kids,
    ok so Im not exactly tech savy & your probably going to cringe when i tell you im working on AE 7.0 but i have a problem peeps and that is my render queue!!!
    basically i have a really heavy render project, theres a million layers in the main composition and about 20 variations of this composition in which I am unsuccessfully rendering. I can only render one comp at a time which takes about 3-4 hours and when i set up a render queue, it fails after the first composition has rendered!
    Any suggestions?
    Kyle Hamrick replied 17 years ago 2 Members · 1 Reply
  • Kyle Hamrick
    May 4, 2009 at 6:26 pm
    …What Dave said.
    If you want to try some troubleshooting yourself, here are some things to look for:
    – Is it consistently failing at the same spot? If so, that’s where to begin looking for the problem. Could be an effect that’s using up too much memory, a reference to a file that is corrupt or moved, etc. Find that spot, and start testing. Maybe set up a render area about 1 sec long, over that trouble spot, so you can start turning layers off one-by-one until the render succeeds. Keep narrowing it down until you find your problem.
    – Is AE giving you any sort of error message or code? If so, Google is your friend. I doubt there’s any problem you can create in AE that someone else hasn’t already solved elsewhere.
    – You said you’re basically making 20 variations of the same thing. Once you get your problem pinned down and solved, you should probably look into doing some pre-rendering. For example, if all of these projects use the same background elements, pre-render that background only, which can then help significantly decrease your render times. Do a little searching on this topic – it’s essentially the same as doing your normal renders, but with a few minor changes.
    Good luck!
    Kyle Hamrick
    Editor/Motion Graphics Artist
    http://www.kylehamrick.com
