Activity Forums Media 100 AE render settings for HD?
  • AE render settings for HD?
    Posted by Bobby Mosaedi on April 3, 2006 at 12:15 am
    rendering some stuff for HD out of after effects, most of the compositions i did before did not have a lot of movement, so i thought they were ok. but this partiucular project has lots of moving text and graphics and my renders turned out bad. here were my settings:
    Render Settings:
    Best Quality
    Field Dominance : Upper field first
    motion blur: on for checked layers
    Output Module:
    compression type: Media100HD
    depth: millions of colors
    colorimetry: ITU Rec 709
    field dominance: upper
    chroma filter: resample
    search alpha channel for active area : checked
    1920×1080
    no audio
    are the settings for the output module correct? I went back to render settings and turned field dominance off and it helped pretty good, but im still not getting the smooth motion im used to. any ideas? thanks
    Floh Peters replied 20 years, 5 months ago 2 Members · 3 Replies
  • Floh Peters
    April 3, 2006 at 6:35 am
    For HD Pal you are correct. For NTSC I think it is lower field first, but I
  • Bobby Mosaedi
    April 4, 2006 at 7:22 pm
    i edit for NTSC… i think its upper field for NTSC HD, but lower field for 720×486 using the Media100HD codec… golly this is confusing.
  • Floh Peters
    April 4, 2006 at 9:22 pm
    To check if your field settings are right you can step through the fields in Media 100 HD. Use the Command-RightArrow button to step forward a field or Command-RightArrow to step back a field. When doing this you should see pretty easily if your motion is field correct.
