Activity Forums Adobe After Effects AE render quality again…
  • AE render quality again…
    Posted by Nick Detomaso on May 25, 2005 at 8:01 pm
    I’ve read all the posts I could find on AE render quality and still am confused!
    I’m using AE to green screen DV footage. I export my clips from Premiere as microsoft DV AVI. I import the footage as microsoft DV AVI into AE, do the keying and export the comp as lossless video for windows (Quality on high) in the render que.
    I then import the composites into Premiere and place them onto the timeline. Premiere then renders them again.
    The video looks like it is deinterlaced,which isn’t all bad, but I must be doing something wrong. I tried turning on interlacing (lower field first) and it seems to jitter.
    What should I be doing to get my original video quality back?
    Andrew Yoole replied 21 years, 3 months ago 4 Members · 4 Replies
  • Joe Chao
    May 25, 2005 at 8:54 pm
    I think that microsoft DV AVI format will make your footage lose some details.Try TGA sequences.And I interlacing should be turned on as well.
    My name is always misread as COW……..:)
    so I got this ID:
    friendcao2004@hotmail.com
  • Filip Vandueren
    May 25, 2005 at 8:58 pm
    Did you interpret as interlaced (AE will prob. do that automatically when it sees it’s a DV file)
    Then, did you render with fields.
    If you didn’t, only the first field is used in the final render.
  • Nick Detomaso
    May 25, 2005 at 9:11 pm
    Thanks for the help. I tried these settings and got GREAT results:
    Import the footage, then Interpret footage, Seperate Fields, Lower First, Motion Dection On (Seems to be the key to making interlaced video work)
    Render Settings- Quality Best, Resolution Full, Field Render Lower First
    Output Module- Click on lossless, Format Options- Microsoft DV
    I’m getting back what looks like better footage than I’m putting in!
  • Andrew Yoole
    May 26, 2005 at 5:52 am
    If you have the drive space, avoid using the DV codec until the very last stage (going back to DV tape!) Use Quicktime Animation (100% Quality) for all your intermediate rendering steps. You’ll get much better image quality, especially if you’re using chromakey.
