Activity › Forums › Adobe After Effects › AE Render problem
AE Render problem
Posted by Skandaless on January 11, 2007 at 8:35 pmI need some help with the following. I created a 720
Skandaless replied 19 years, 7 months ago 56,974 Members · 2 Replies -
Skandaless
January 12, 2007 at 10:54 amHi Dave, thanx for your response. I did use the D1/DV PAL Pixel Aspect Ratio of 1.066 and it looks fine in AE, and when i render it into a MOV. file it also looks great. I still have to look into AE help for some more info on the Output Module but thanx for pointing out the fact that Encore can use other codecs as well, that sure helps for now.
Stephan
