Activity › Forums › Adobe After Effects › AE remove logo behind actor
  • AE remove logo behind actor
    Posted by Chris Alexander on June 25, 2008 at 8:36 pm
    I need to remove a projected logo on the wall behind an actor. The actor moves about in front of the logo in a clip around 15 seconds long. In After Effects how can I “paint out” this logo. Thanks.
    Chris Wright replied 18 years, 3 months ago 3 Members · 2 Replies
  • Bill Kelly
    June 26, 2008 at 12:05 am
    The only other possibility I can think of for you, and to be honest it probably won’t give you good results (but you could try it), is if the logo only has a couple, solid colors in it. You may be able to use Keylight to key out each individual color of the logo. You’d probably have to do a lot of tweaking and even then I have doubts as to how it would look, but you could give it a shot.
    Like Dave says above, either reshooting or rotoscoping is probably your best bet.
  • Chris Wright
    June 26, 2008 at 12:31 am
    monet track, remove logo, 20 min later grab a smoke. or roto AE 9999 frames.
